[GRASS5] Libgrass_gis on Mingw - open.c patch
Javier A. Yebrin
javier.yebrin at ing.unitn.it
Mon May 16 06:40:51 EDT 2005
These are the raster modules currently built on MINGW (note that built
does'nt mean working, nor fully tested):
r.average
r.basins.fill
r.bilinear
r.buffer
r.cats
r.circle
r.clump
r.coin
r.colors
r.composite
r.compress
r.contour
r.cost
r.covar
r.cross
r.describe
r.distance
r.drain
r.fill.dir
r.flow
r.grow
r.his
r.in.arc
r.in.ascii
r.in.bin
r.in.gdal
r.in.gridatb
r.in.mat
r.in.poly
r.info
r.kappa
r.le.patch
r.los
r.mapcalc_grass
r.median
r.mfilter
r.mode
r.neighbors
r.null
r.out.arc
r.out.ascii
r.out.bin
r.out.gridatb
r.out.mat
r.out.mpeg
r.out.pov
r.out.ppm3
r.param.scale
r.patch
r.proj
r.quant
r.random.cells
r.random.surface
r.reclass
r.recode
r.report
r.resample
r.rescale
r.rescale.eq
r.series
r.slope.aspect
r.statistics
r.stats
r.sum
r.sun
r.sunmask
r.surf.area
r.surf.contour
r.surf.idw
r.texture
r.thin
r.topidx
r.topmodel
r.transect
r.univar
r.water.outlet
r.watershed
r.what
> -----Original Message-----
> From: Radim Blazek [mailto:blazek at itc.it]
> Sent: Monday, May 16, 2005 9:52 AM
> To: Javier A. Yebrin
> Cc: grass5 at grass.itc.it
> Subject: Re: [GRASS5] Libgrass_gis on Mingw - open.c patch
> Javier A. Yebrin wrote:
> > Hi all!
> > This patch solves the problem of binary files read/write
> under win32.
> > Practically forces the c runtime to binary-mode file translation as
> > default. It is not the cleanest way but it is simple.
> > More info at: http://www.mingw.org/MinGWiki/index.php/binary
> > Cheers,
> > Javier Yebrin
> I have submitted the patch to CVS HEAD.
> Can you summarize what is currently working on Windows/MinGW?
> Thanks
> Radim
