[GRASS5] Re: [GRASSLIST:6791] Re: neighbors of polygons
Martin Landa landa at gama.fsv.cvut.cz
Mon May 16 12:47:33 EDT 2005
> - v.category: does not have a parameter layer (at least in my grass 5.7)
> - assigning cat to boundaries means: having for all boundaries the
> associated cat (ie polygon(s)-IDs) they belong to?
> >v.to.db option=sides -p
> - v.to.db:  parameter option does not have a value sides (only cat,
> areas, length, count, coor, query)
so, you should use GRASS 6.x ...
Martin
Martin Landa <landa at gama.fsv.cvut.cz> * http://gama.fsv.cvut.cz/~landa *
CTU Prague, Faculty of Civil Engineering, Czech Republic
