[GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
Maciek Sieczka
werchowyna at epf.pl
Mon May 16 17:03:02 EDT 2005
fine, I'll check it tomorrow
thank you
Maciek
----- Original Message -----
To: "Paolo Cavallini via RT" <grass-bugs at intevation.de>;
<grass5 at grass.itc.it>
Sent: Monday, May 16, 2005 10:08 PM
Subject: Re: [GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map
>I think this was fixed in the update I posted today.
> Michael
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>> From: Request Tracker <grass-bugs at intevation.de>
>> Reply-To: Request Tracker <grass-bugs at intevation.de>
>> Date: Mon, 16 May 2005 16:32:14 +0200 (CEST)
>> To: <grass5 at grass.itc.it>
>> Subject: [GRASS5] [bug #3246] (grass) d.vect.thematic fails when the map
>> is in
>> another mapset
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3246
>> Subject: d.vect.thematic fails when the map is in another mapset
>> Platform: GNU/Linux/i386
>> grass obtained from: Trento Italy site
>> grass binary for platform: Compiled from Sources
>> GRASS Version: grass61_cvs_2005_05_16
>> Michael
>> The map 'gminy_zw' is in mapset 'robot'. When displayed with
>> d.vect.thematic
>> from within the 'robot' mapset all is OK. But when from another mapset
>> d.vect.thematic fails:
>> d.vect.thematic 'themetype=graduated colors' themecalc=interval
>> map=gminy_zw at robot column=KK layer=1 type=area icon=basic/circle size=5
>> maxsize=20 nint=4 colorscheme=red-blue singlecolor=red
>> dbmi: Protocol error
>> awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
>> Thematic map legend for column KK of map gminy_zw at robot
>> Value range: -
>> Mapped by 4 intervals of
>> Color(R:G:B) Value
>> 250:0:0 >0 - 0
>> BTW - can the colortable be stored in GRASSRGB column? I guess you where
>> discussing this on the list but I can't find the option in
>> d.vect.thematic.
>> Many thanks for this module, I'm sure it will be usefull for many of us.
>> Maciek
>> -------------------------------------------- Managed by Request Tracker
> grass5 mailing list
> http://grass.itc.it/mailman/listinfo/grass5
