[GRASS5] d.nviz functional?
Markus Neteler
neteler at itc.it
Wed May 18 07:49:00 EDT 2005
Hi Bob,
On Tue, May 17, 2005 at 04:43:35PM -0300, Bob Covill wrote:
> Hi Markus,
> I have dug into the scripting problem and found a potential problem.
> Each command in the script is executed by the procedure SendScriptLine.
> This procedure can be found in script_support.tcl.
> This procedure uses the TK "send" command which is probably the source
> of the problems.
> To identify if the send command is failing change the following line
> from SendScriptLine
> catch {send $ProcessName "$line"} rval
> to
> This will allow any errors from "send" to be output to stderr.
Magic! Now it works...!
I changed
return $rval
to
return 1
and now NVIZ immediately starts the render the flight.
Maybe 'return 1' is wrong, but keeping the original 'return $rval'
line led to
Error in startup script: can't read "rval": no such variable
Maybe this was the bug: rval not defined.
> With my CygWin installation I recieved the following error ...
> X server insecure (must use xauth-style authorization)
This is a different error, I assume.
> Let me know if you get a similar error. I am not sure of a work-around
> for this yet. Presumably any any system not using xauth will have the
> same problem?
Probably (I know little about xauth).
How should I change the catch line in CVS? It seems to depend
on the tcltk version.
Thanks for finding it!
Markus
