[GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the map is in another mapset
Michael Barton michael.barton at asu.edu
Sun May 22 12:49:57 EDT 2005
Daniel,
I tried out your code changes to d.vect.thematic.
There were a few odd display glitches, but overall it worked well.
I've gone ahead and rewritten the graduated points routine along the lines
of your graduated colors routine. It revealed a problem I  didn't notice
previously with the graduated points, so I fixed it. I made a couple of
other improvements to the points legend.
I also added a flag option for math notation brackets, so everyone should be
happy (or at least happier).
Could you try it out and see what you think? If you want to test the
graduated point routine, just use areas and select centroids as the vector
type.
Lorenzo Moretti suggested an option to write out the thematic mapping as a
group file for the GIS Manager. This is intriguing and I might try to add
this in the next update if there is some interest.
Michael
On 5/20/05 12:39 PM, "Daniel Calvelo Aros" <dcalvelo at minag.gob.pe> wrote:
> From: Michael Barton <michael.barton.asu.edu>
> Sent: Fri, 20 May 2005 10:39:53 -0700> If you want to change your local
> version, please go right ahead and
>> see how it looks.
>> Let's not change the cvs version until we have a consensus (if
>> possible). For work in my field (archaeology) and from what I know
>> of geography, the notation
>> ]min ; max]
>> would be meaningless--although it might be perfect for your field
> Ok, let's wait for things to settle. I attach a heavily overhauled version of
> d.vect.thematic that does the following:
> - takes care of the min included (it *is* in the first interval)
> - is prepared for any bracketing needed, but uses the "a - b" notation
> currently
> - solves the problem of using stdevs and having eg. min>mean-2stdev
> The code, though, is much shorter since I've changed the way the script is
> architectured. That's why I send it in toto instead of patch:
> - I added an (internal, e.g. not accesible to users) "annotation" facility,
> which miught be important for stdev-type classifications.
> - I've factored all the query draw and print sections to work from a set of
> breakpoint definitions, which are calculated differently for each of the
> themecalc methods. It complicates thing a little but it allows for easier
> classifier additions later, and is less cumbersome for further enhancements
> (only one spot for changes).
> - I've left the points part alone, since I don't have point data at hand to
> test against, and I'd like your comments before refactoring further.
> Please test and comment.
> Daniel.
> PS. this is not standalone as it still requires v.univar.sh
>> Michael
>> ______________________________
>> Michael Barton, Professor of Anthropology
>> School of Human Evolution and Social Change
>> Arizona State University
>> Tempe, AZ  85287-2402
>> USA
>> voice: 480-965-6262; fax: 480-965-7671
>> www: http://www.public.asu.edu/~cmbarton
>>> From: Daniel Calvelo Aros <dcalvelo at minag.gob.pe>
>>> Reply-To: <daniel.calvelo at minag.gob.pe>
>>> Date: Fri, 20 May 2005 12:22:08 -0500
>>> To: Michael Barton <michael.barton at asu.edu>, Maciek Sieczka
>>> <werchowyna at epf.pl>, Paolo Cavallini via RT <grass-bugs at intevation.de>
>>> Cc: grass devel <grass5 at grass.itc.it>
>>> Subject: Re: [GRASS5] Re: [bug #3246] (grass) d.vect.thematic fails when the
>>> From: Michael Barton <michael.barton at asu.edu>
>>> Sent: Fri, 20 May 2005 10:12:41 -0700
>>>> I tend to agree with you that
>>>> min - max
>>>> looks better than
>>>>> min - max
>>>> although the second one is more accurate.
>>>> What does everyone else think?
>>> I'd like the math standard :
>>> [min ; cut1]
>>> ]cut1 ; cut2]
>>> ]cutn ; max]
>>> Note the *included* min. I'll see if I can put that into your current
>>> script,
>>> Michael.
>>> Daniel.
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
> ------- End of Original Message -------
C. Michael Barton, Professor of Anthropology
PO Box 872402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20050522/2dde2f02/d.vect.obj
