[GRASS5] Updated d.vect.thematic
Daniel Calvelo Aros
dcalvelo at minag.gob.pe
Mon May 23 13:40:06 EDT 2005
Hi Moritz,
Try to find the spots in the code having things like 'printf("#%2X%2X' in the
awk code and change each of those "%2X" to "%02X", note the "0" which means
"pad left with zeros".
This is a wild guess as I haven't seen the code, but Michael had just this
sort of trouble yesterday night. Which also means it will get fixed very soon.
Daniel.
-- Daniel Calvelo Aros
---------- Original Message -----------
From: "Moritz Lennert" <mlennert at club.worldonline.be>
To: "Michael Barton" <michael.barton at asu.edu>
Cc: "Daniel Calvelo Aros" <dcalvelo at minag.gob.pe>, "Lorenzo Moretti"
<lorenzo.moretti at bologna.enea.it>, "Jachym Cepicky"
<jachym.cepicky at centrum.cz>, "grass devel" <grass5 at grass.itc.it>
Sent: Mon, 23 May 2005 19:27:10 +0200 (CEST)
Subject: Re: [GRASS5] Updated d.vect.thematic
> On Mon, May 23, 2005 19:07, Michael Barton said:
> > OK,
> > I¹ve managed to add the option to save as a GIS Manager group (Thanks go to
> > Daniel for helping with parsing rgb into hex). I think this deals with most
> > of the suggestions and updates that everyone made. Thanks to you all.
> I get the following error when trying to load the group file (I've attached
> the group file for info). Seems that the color codes are not completely
> correct:
> invalid color name "# 0 0FA"
> (processing "-fill" option)
> invoked from within
> "$leg create rectangle $x1 $y1 $x2 $y2 -outline $opt($id,color)
> -fill $opt($id,fcolor)"
> (procedure "DmVector::legend" line 41) invoked from within
> "DmVector::legend $id"
> (procedure "DmVector::set_option" line 7) invoked from within
> "DmVector::set_option $current_node $key $val"
> ("vector" arm line 2) invoked from within "switch $type {
> group { DmGroup::set_option $current_node $key $val }
> raster { DmRaster::set_option $current_node $key $..."
> ("default" arm line 8) invoked from within "switch $key {
> Group {
> if { [regexp -- {^File (.+)} $val r leftover] && ($leftover !=
> $::Dm::filename)} {
> set val "<-- $leftover"..."
> (procedure "Dm::load" line 46)
> invoked from within
> "Dm::load $::Dm::filename_new"
> (procedure "Dm::OpenFileBox" line 20)
> invoked from within
> "Dm::OpenFileBox .mainframe.topf.tb1"
> ("uplevel" body line 1)
> invoked from within
> "uplevel \#0 $cmd"
> (procedure "Button::_release" line 18)
> invoked from within
> "Button::_release .mainframe.topf.tb1.bbox2.b1"
> (command bound to event)
------- End of Original Message -------
