[GRASS5] drawing icons
Tue May 24 19:34:57 EDT 2005
> is there quick manual, which would tell me, how to draw icons on the
> monitor? I would like to add these in d.legend. I looked at the code
> of d.vect, but I can not say, that I would understand it much. Is
> there some better place, where to look?
see lib/symbol/README
Otherwise d.vect source code is the best place to look.
display/d.vect/plot1.c
starting with line 81:
 /* Note: this should go to some library function */
also main.c, lib/symbol/*.c, and include/symbol.h
It would be really great to make a D_symbol() and D_polygon() functions
in lib/display/ and then add to d.graph. (as a similar tool to ps.map's
point command)
Hamish
