[GRASS5] [bug #3277] (grass) d.vect.thematic fails with DOUBLE
Michael Barton michael.barton at asu.edu
Wed May 25 12:22:38 EDT 2005
Could someone else test this with the current version? I've tested it by
updating an "area" column with values via v.to.db. This provides non-integer
values in a dbf format. However, the native dbf format doesn't explicitly
support double precision numbers the way another dbms might.
Since this is done as intervals, there are no statistical calculations done
in v.univar.sh except for maximum and minimum. I've done all the
calculations for thematic mapping in awk. The only thing I can think of is
that there are some records have empty (i.e., NOT 0, but empty or null)
values for the field. Something along this line happened when I was testing
it against the Spearfish roads table. The 'nodata' record had nothing in it
for length. When I opened the table and resaved it, it changed to 0. Then it
calculated OK.  Currently, this does not handle null or empty values. It
would take a rewrite of v.univar.sh to do so, along with a way to specify
them.
If this is not the problem, I'm baffled as to why this is creating an error.
Could anyone else offer ideas?
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ  85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Request Tracker <grass-bugs at intevation.de>
> Reply-To: Request Tracker <grass-bugs at intevation.de>
> Date: Wed, 25 May 2005 11:47:05 +0200 (CEST)
> To: <grass5 at grass.itc.it>
> Subject: [GRASS5] [bug #3277] (grass) d.vect.thematic fails with DOUBLE
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3277
> Subject: d.vect.thematic fails with DOUBLE
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: cvs_25_05_05
> d.vect.thematic works fine with INTEGER but fails with DOUBLE as follows:
> d.vect.thematic map=gminy_zw_2003_prc_dem 'themetype=graduated colors'
> themecalc=interval column=PROD layer=1 type=area icon=basic/circle size=5
> maxsize=20 nint=4 colorscheme=blue-red singlecolor=250:0:0 startcolor=250:0:0
> endcolor=0:0:250 monitor=x1
> awk: cmd. line:1: (FILENAME=- FNR=1) fatal: division by zero attempted
> Thematic map legend for column PROD of map gminy_zw_2003_prc_dem
> Value range:  -
> Mapped by 4 intervals of
> Color(R:G:B) Value
> 0:0:250  . -
> DBMI-DBF driver error:
> SQL parser error in statement:
> SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD >=  and PROD<=
> Error in db_open_select_cursor()
> 62:0:188  . -
> SELECT cat FROM gminy_zw_2003_prc_dem WHERE PROD >  and PROD<=
> 124:0:126  . -
> 186:0:64  . -
> the vector file info:
> GRASS 6.1.cvs (caves_utm33):~ > v.info gminy_zw_2003_prc_dem
>  | Layer:    gminy_zw_2003_prc_dem          Organization:
>  | Mapset:   admin                          Source Date:
>  | Location: caves_utm33                    Name of creator:
>  | Database: /home/grassdata
>  | Title:
>  | Map Scale:  1:1
>  | Map format: native
>  |   Type of Map:  Vector (level: 2)
>  |   Number of points:       0               Number of areas:      23
>  |   Number of lines:        0               Number of islands:    5
>  |   Number of boundaries:   90              Number of faces:      0
>  |   Number of centroids:    23              Number of kernels:    0
>  |   Map is 3D:              0
>  |   Number of dblinks:      1
>  |   Projection: Universe Transverse Mercator (zone 33)
>  |            N: 5739296.326    S: 5660045.543
>  |            E: 633165.320     W: 564573.435
>  |            B: 0.000         T: 0.000
>  |   Digitize threshold: 0.00000
>  |   Comments:
> datbase info:
> db.describe table=gminy_zw_2003_prc_dem driver=dbf
> database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/
> table:gminy_zw_2003_prc_dem
> description:
> insert:yes
> delete:yes
> ncols:14
> column:CAT
> description:
> type:INTEGER
> len:11
> scale:0
> precision:10
> default:0
> nullok:yes
> select:yes
> update:yes
> column:NAZWA
> description:
> type:CHARACTER
> len:15
> scale:0
> precision:0
> default:
> nullok:yes
> select:yes
> update:yes
> column:PRZYR_PRC
> description:
> type:DOUBLE PRECISION
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRZEDPR
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PROD
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:POPROD
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRAC
> description:
> len:8
> scale:2
> precision:6
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:PRAC_ROL
> description:
> len:6
> scale:2
> precision:4
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:BEZR_REJ
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:ZATR
> description:
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:NIEZATR
> description:
> len:5
> scale:2
> precision:3
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:GESTOSC
> description:
> len:7
> scale:2
> precision:5
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:WIES_KM2
> description:
> len:4
> scale:2
> precision:2
> default:0.000000
> nullok:yes
> select:yes
> update:yes
> column:grassrgb
> description:
> type:CHARACTER
> len:11
> scale:0
> precision:0
> default:
> nullok:yes
> select:yes
> update:yes
> Maciek
> -------------------------------------------- Managed by Request Tracker
