[GRASS5] viewing map attribute table
Radim Blazek
blazek at itc.it
Mon May 30 06:09:38 EDT 2005
Moritz Lennert wrote:
> On Wed, May 25, 2005 18:14, Michael Barton said:
>>This would be very nice. Perhaps we should also have a db.dropcolumn.
> I don't think that ALTER TABLE DROP COLUMN is implemented in the GRASS SQL.
> Radim ?
No, it is not implemented.
BTW, v.db.updatecol could be probably called simply v.db.update, there
are no other properties which could be updated AFAIK.
Radim
