[GRASS5] Readline completion for grass
Radim Blazek
blazek at itc.it
Mon May 30 07:26:43 EDT 2005
Daniel Calvelo Aros wrote:
> From: Hamish <hamish_nospam at yahoo.com>
> Sent: Fri, 27 May 2005 09:54:12 +1200
>>Were you aware of the existing implementation?
> No.
>>look for "GRASS shell extension" at
>> http://grass.ibiblio.org/download/addons.php
>>note the link is 404 not-found, so not much use to anyone. Maybe someone
>>has an old copy though? This will surely be pre-GRASS 6 though so yours
>>will be more up to date, but maybe it could help you.
> Certainly it could.
> Radim, you seem to have got circa 2002; is it still around? It didn't made it
> to the source distribution, and Alexandre Sorokine (the original author) is
> out of the web currently, it seems.
I have put it here:
http://mpa.itc.it/radim/grass-complete-sorokine/
I am not sure if this is his last version.
Radim
>>Once you are happy with it, it can be added to the Add-Ons page in
>>the wiki. http://grass.gdf-hannover.de/twiki/bin/view/GRASS
> Ok.
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
