[GRASS5] Re: r.out.gdal
Hamish
hamish_nospam at yahoo.com
Mon May 30 07:34:38 EDT 2005
> > r.out.gdal - broken with quoting problem.
> > (help?)
> Is it possible that this problem was introduced when
> making 'Krovak' et al. functional? For a while r.out.gdal
> worked quite well.
I believe that is correct.
The bug should be easy to fix though. It's just shell quoting:
http://grass.itc.it/pipermail/grassuser/2005-May/029045.html
well actually it seems to be putting 'quotes' around [brackets] with
spaces in them.
Hamish
