[GRASS5] [bug #3277] (grass) d.vect.thematic fails with DOUBLE
Tue May 31 20:23:29 EDT 2005
> > I could add the regex line markers, but have no idea how I can test
> > this in the situation Maciek reports. How do you get a <double
> > precision double precision> column??? Maybe someone else could add
> > these and test it for me???
> If you have a column PROD and another column with "PROD" in it, e.g.
> PROD2, the grep step will pick out both.
Hamish
