[GRASS5] Re: Testing GRASS PLUGIN...
Radim Blazek radim.blazek at gmail.com
Thu Nov 3 04:32:52 EST 2005
I am using  GPJ_osr_to_grass() and G_make_location().
Paul, can it be that GRASS does not understand a projection created
by GPJ_osr_to_grass()?
BTW, it seems that that GPJ_osr_to_grass() returns always 1 even if it fails
so I test if pointer is set or 0.
Radim
On 11/2/05, Luca Casagrande <luca.casagrande at gmail.com> wrote:
> Hi to all!
> I was testing the great plugin Radim has made, and i discovered that if i
> create a NEW LOCATION from qgis and then print out the region info using
> g.region -p inside GRASS, the datum is not recognized:
> GRASS 6.0.1 (provadatum):~ > g.region -p
> projection: 3 (Latitude-Longitude)
> zone:       0
> datum:      ** unknown (default: WGS84) **
> ellipsoid:  a=6378388 es=0.00672267
> north:      90N
> south:      90S
> west:       180W
> east:       180E
> The proj string used in qgis was: +proj=longlat +ellps=intl +pm=rome +no_defs
> (Monte Mario Rome)
> Am I missing something?
> Thx
> gtalk: luca.casagrande at gmail.com
> skype : thedoktor78
> msn: doktoreas at hush.com
