[GRASS5] gdal 1.3.1 and Terra ASTER hdf files
Carl Anderson
carl.anderson at vadose.org
Thu Nov 3 21:43:11 EST 2005
Michael Barton wrote:
> I work with the GRASS GIS project and haven’t been able to import and
> georeference Terra ASTER hdf files since gdal version 1.2.6. I
> recently compiled and installed the most recent 1.3.1 (as of last
> week) and it still produces errors (see below). As an update, I just
> tried r.in.gdal from GRASS 6.1 cvs and it will not import the ASTER
> files either. First it did not recognize the projection, so I set the
> override projection flag. Then it won’t recognize a band number or
> import all bands (default).
> So, back to my original question, what has changed since 1.2.6 that
> keeps me from importing ASTER’s? Could this be fixed?
I'll try to relate what I understand. The GDAL 1.2.6 driver was limited
and did not do a very good job with all of the information in HDF files.
The old HDF sub driver was changed to newer driver to improve the
overall quality. In 1.2.9? (certainly by 1.3.0) the driver was working
well. The downside is that you cannot directly "read" projected data
from a HDF and must gdalwarp L1A and L2A HDF files to a specific
projection to get access to projected data. If you look at any ASTER HDF
file you will see projected data mixed in with sensor calibration
samples and other non geophysical data. I suspect that is the reason
that a ASTER HDF appears unprojected through the GDAL drivers.
FWTools 1.0.0a4 == GDAL 1.3.1.0, FWTools 1.0.0a4, released 2005/10/15
/usr/local/FWTools-linux-1.0.0a4/bin_safe/gdalinfo
AST_L1B_00306152005162314_06242005150609.hdf
PGEVERSION=06.00R00
PROCESSINGLEVELID=1B
MAPPROJECTIONNAME=Universal Transverse Mercator
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"AST_L1B_00306152005162314_06242005150609.hdf":VNIR_Swath:ImageData1
SUBDATASET_1_DESC=[4200x4980] ImageData1 (8-bit unsigned integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"AST_L1B_00306152005162314_06242005150609.hdf":VNIR_Swath:ImageData2
SUBDATASET_2_DESC=[4200x4980] ImageData2 (8-bit unsigned integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
/usr/local/FWTools-linux-1.0.0a4/bin_safe/gdalwarp -t_srs EPSG:26916
-tps b.tif
/usr/local/FWTools-linux-1.0.0a4/bin_safe/gdalinfo b.tif
Upper Left ( 714191.497, 3718692.860) ( 84d41'31.09"W, 33d35'11.27"N)
You will need to warp each band from the HDF file before importing.
C.
> Thanks much
> Michael Barton
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
> <http://www.public.asu.edu/%7Ecmbarton>
> On Thu, Nov 03, 2005 at 09:02:00AM -0700, Michael Barton wrote:
>> I tried to import Terra ASTER hdf files using the latest gdalwarp and my
>> r.in.aster script last week, after compiling the latest version
> (1.3.1) of
>> gdal. It still gives an error that gdal cannot read the projection
> info in
>> the ASTER hdf's. This has been an issue since 1.2.7 (version 1.2.6 still
>> works fine on my Mac).
>> I haven't tried r.in.gdal, but suspect that I'd have similar problems
>> (please correct me if wrong!).
>> Is there a fix or workaround to this? All ASTERs are in WGS84, UTM
>> projection (the zone varies of course).
>> Michael
>> USA
>> www: _http://www.public.asu.edu/~cmbarton
> _>
>> > From: Hamish <_hamish_nospam at yahoo.com_>
>> > Date: Thu, 3 Nov 2005 14:44:44 +1300
>> > To: Jonathan Greenberg <_jgreenberg at arc.nasa.gov_>
>> > Cc: <_GRASSLIST at baylor.edu_>
>> > Subject: [GRASSLIST:8849] Re: HDF files?
>> >> Is there any way to get HDF files into GRASS? I saw there is an
>> >> r.in.hdf command, but Grass 6.0.1 on MacOS X is throwing and error
>> >> when I try it: command not found
>> > Use r.in.gdal, but GDAL must be built using the --with-hdf4 switch.
>> > _http://www.remotesensing.org/gdal/frmt_hdf4.html
> _> >
>> > try "gdal_translate --formats" and check for:
>> > HDF4 (ro): Hierarchical Data Format Release 4
>> > HDF4Image (rw+): HDF4 Dataset
>> > or just "gdalinfo <dataset>" and see if it understands the file(s).
>> > "r.in.gdal -f in=dummy out=dummy" will also list supported GDAL
> formats.
>> > (often there will be about 50 of them)
>> > Hamish
