[GRASS5] importing .e00 files
Kirk R. Wythers
kwythers at umn.edu
Fri Nov 4 09:30:22 EST 2005
On Nov 3, 2005, at 7:55 PM, Hamish wrote:
>> Importing areas...
>> + v.in.ogr -c -o dsn=glo10k layer=LAB,ARC type=centroid,boundary
>> output=glo10k
>> ERROR: Cannot open data source: glo10k
>> + '[' 1 -eq 1 ']'
>> + echo 'An error occurred. Stop.'
>> + rm -rf 13707.e00 glo10k info
> what if you comment out the "rm" line? (244) (add a # at the start
> of it)
On my system the last line in the file is 240. Are you referring to
the line:
## area
rm -rf $E00TMP.e00 $E00SHORTNAME info 2>&1 > /dev/null
or one of these:
#### clean up the mess
rm -f "$TMPDIR"/$E00NAME.e* "$TMPDIR"/$E00NAME.E*
rm -rf $E00TMP.e00 $E00SHORTNAME info $E00NAME.cat.$E00TMP.e00 2>&1
> /dev/null
cd ..
> Then you can try v.in.ogr by hand, use ogrinfo, see what the file
> sizes
> are, etc. (files are in a temp dir)
Can you give a little more detail here Hamish. Thanks.
> Hamish
