[GRASS5] importing .e00 files
Kirk R. Wythers
kwythers at umn.edu
Fri Nov 4 13:52:12 EST 2005
On Nov 3, 2005, at 3:18 PM, Shaun Walbridge wrote:
> Hey Kirk,
> Sorry I didn't respond earlier; your message was picked up by my
> GRASS mailing list filter and I hadn't gone through the messages.
> Are you still having problems importing your .e00 files? If so,
> there is an alternative approach: you can use the `avcimport' tool
> (came with the library you recently built) to convert the e00
> compressed coverage into a simple binary coverage (It just unpacks
> the coverage into its native, non-compressed form). Afterward, you
> can use v.in.ogr to convert the Arc Coverage to a grass vector.
> The documentation is in v.in.ogr.html, and the example they use is:
> *v.in.ogr dsn=*/coverage/ *layer=*/LAB,ARC/ *type=*/
> centroid,boundary/ *output=*/mymap
In addtion to working with v.in.e00, I have also tried Shaun's
suggestion of using avcimport manually (creates 6 .adf files), then
using v.in.ogr to import. I'm getting the same error "Cannot open
data source".
GRASS 6.1.cvs (arrowhead_utm):~ > v.in.ogr dsn=~/Desktop/tmp/
glo10ktest/ out=glo10ktest
ERROR: Cannot open data source:
/Network/Servers/truffula.fr.umn.edu/Volumes/disk1/home1/
kwythers/Desktop/tmp/glo10ktest/
This is probably caused by the same issue that was giving the
v.in.e00 script fits. Any other thoughts?
Kirk
> There is more information on the various layer types here:
> http://www.gdal.org/ogr/drv_avc.html/
> Hope this helps,
> Shaun
> Kirk R. Wythers wrote:/
>> Hey Shaun,
>> I'm still having some trouble with those .e00 files. I built
>> avce00 and e00compr, and installed:
>> e00conv
>> avcdelete
>> avcexport
>> avcimport
>> avctest
>> in /usr/local/bin
>> I am no longer getting the error e00conv not found, but I still
>> get the error "can't open data source:"
>> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=~/Desktop/
>> glo10k.e00 type=area vect=glo10k
>> An error may appear next which will be ignored...
>> E00 Compressed ASCII found. Will uncompress first...
>> ...converted to Arc Coverage in current directory
>> Importing areas...
>> ERROR: Cannot open data source: glo10k
>> An error occurred. Stop.
>> Am I still missing something?
>> On Nov 2, 2005, at 12:29 PM, Shaun Walbridge wrote:
>>> Hi Kirk,
>>> You can just build avce00. It should be pretty straightforward
>>> to set up. Then either install the binaries to somewhere on
>>> your $PATH, or edit v.in.e00 to point to the locations. The
>>> GRASS dev folks should probably include it as a configure
>>> option, but I guess they see it as being external to the core
>>> GRASS stuff.
>>> - Shaun
>>>> Thanks Shaun. Does grass need to be re-compiled, or can I just
>>>> build avce00?
>>>> On Nov 2, 2005, at 12:05 PM, Shaun Walbridge wrote:
>>>>> Kirk,
>>>>> The v.in.e00 script is dependent on your system having avce00
>>>>> already installed. You can download this library at: http://
>>>>> avce00.maptools.org/.
>>>>> -Shaun
>>>>>> Does anyone have any ideas as to what might be wrong with
>>>>>> the following command:
>>>>>> GRASS 6.1.cvs (arrowhead_utm):~ > v.in.e00 -v file=/Volumes/
>>>>>> disk2/ data2/reich_lab/data/fia/glo10k.e00 type=area vect=glo10k
>>>>>> /usr/local/grass-6.1.cvs/scripts/v.in.e00: line 175:
>>>>>> e00conv: command not found
>>>>>> Importing areas...
>>>>>> This files appears to open fine with ArcView, so I don't
>>>>>> think the file is bad. However, I am confused by the "can't
>>>>>> open data source" message.
>>>>>> Thanks,
>>>>>> Kirk
>>>>>> _______________________________________________
>>>>>> grass5 mailing list
>>>>>> grass5 at grass.itc.it
>>>>>> http://grass.itc.it/mailman/listinfo/grass5
