[GRASS5] status of Tcl/Tk Aqua support on Mac OS X
Sat Nov 5 12:49:49 EST 2005
William Kyngesburye wrote:
> As I understand it, in GRASS 6 (or 6.1 CVS at least), the most of the
> Tcl/Tk interface has been rewritten so that it now runs in Mac OS X's
> Tcl/Tk Aqua.  The part that still needs a UNIX build of Tcl/Tk is
> NVIZ, and I think that has something to do some X11 program it uses
> to get window info?
No, that was the tcltkgrass GUI, which has been obsoleted by d.m.
NVIZ needs the Unix/X11 build because it uses OpenGL, which needs
support from the window system.
> Is there any C code in NVIZ that needs the UNIX Tcl/Tk?
Yes.
> Does this sound right?
No.
> Is 6.0.1 in line with 6.1 CVS?
Mostly.
> What are the bits in NVIZ that need the UNIX Tcl/Tk?
The Togl widget (OpenGL "canvas" widget for Tk) has two versions of
most of its core functions: one using X11 and glX (functions for
managing OpenGL contexts under X11), the other using Win32 and wgl
(functions for managing OpenGL contexts under Win32).
There are a few glX calls elsewhere in NVIZ, primarily in do_zoom.c.
> If an  alternative could be found that works with Tcl/Tk Aqua, is it as
> simple as changing some command references in the Tcl code?
To make NVIZ work natively on OSX/Aqua, someone would need to modify
Togl and do_zoom.c to include native Aqua and agl (the Apple
equivalent of glX/wgl) implementations.
A related project would be to modify do_zoom.c so that it works with
Win32/wgl. That would allow NVIZ to run natively on Windows. This is
easier than the Mac case, as Togl already includes Win32/wgl support.
