[GRASS5] Re: Developing a New Grass UI
Michael Barton
michael.barton at asu.edu
Mon Nov 7 00:48:56 EST 2005
Thanks again David. These are the kinds of issues I'd like to make sure we
discuss BEFORE we set out building the next generation UI.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: David Finlayson <dfinlays at u.washington.edu>
> Reply-To: <dfinlays at u.washington.edu>
> Date: Sun, 06 Nov 2005 21:45:46 -0800
> To: Michael Barton <michael.barton at asu.edu>
> Subject: Re: Developing a New Grass UI
> On 11/6/05, Michael Barton <michael.barton at asu.edu> wrote:
>> This way you are issuing a set of commands to the UI, rather than having the
>> UI run a set of independent display commands, a subtle, but significant
>> difference.
> Indeed, it cuts both ways. By creating a display driver that is
> fundamentally object-oriented with a hierarchy of display objects
> (lines, points, rasters, map decorations, view points, etc.) you will
> need to create a mini-language to access these objects from a script.
> Alternatively, you can expose the graphics objects to a scripting
> language like Python (think about how you manipulate Tk with Tcl).
> Rather than working with a high-level command, users will need to
> learn an API to the monitor display. It can be powerful, of course,
> but now simple map automation requires mastering both the API and a
> real programming language.
> I didn't get into it too much in my previous post, but this is exactly
> the problem that ESRI faces with ArcGIS. They have a very powerful
> object-oriented API that serious programmers can access at low level.
> But it requires a lot of boilerplate code to get at even simple
> functions and way too much understanding of the underlying
> architecture. I once replaced a 10 line script in AML (the old command
> line language of ArcInfo) with more than 1000 lines of visual basic to
> do exactly the same thing in ArcGIS. That project drove me to start
> using GRASS. I wanted a GIS without the object oriented design
> patterns.
> Anyway, I hope you understand that I DO think a new GUI is a good
> idea. I am really excited about Q-GIS and hope that it develops into
> something as good as ArcGIS is currently. (personally, I think Q-GIS
> should be the GUI to grass). I just worry that we will throw the baby
> out with the bath water "modernizing" the GRASS UI.
> David
