[GRASS5] Re: [GRASSLIST:8559] Re: gshhs
Markus Neteler neteler at itc.it
Thu Nov 10 14:32:37 EST 2005
On Thu, Nov 10, 2005 at 01:23:32PM -0600, bfdi533 wrote:
> Well, I have finally made some progress and have tried my first run.  I
> encountered an Out of Memory error so checked into .../doc/debugging.txt
> and set the DEBUG level so I can see better what is happening.
> Here is the end of what I get now:
> D1/3: V1_open_new_nat(): name = gshhs_c
> D1/3: Vect_get_thresh(): thresh = 0.000000
> D1/3: dig__write_head()
> D1/3: write coor size (0) to head
> D2/3: coor body offset 14
> D3/3: dig_init_plus()
> D1/3: dig_spidx_init()
> D3/3: dig_cidx_init()
> Swapping Enabled
> D3/3: Vect_write_line(): name = gshhs_c, format = 0, level = 1
> Out of Memory.
> Any ideas on where I should go to track this down?
I CC to the developer's list. It probably originates from
grep 'Out of Memory' lib/vector/diglib/allocation.c
      fprintf (stderr, "Out of Memory.\n");
      fprintf (stderr, "\nOut of Memory on realloc.\n");
in function dig_falloc().
Maybe someone in the list has an idea.
 Markus
