[GRASS5] Fw: Re: [GRASSLIST:8983] r.terraflow: wrong data type
Hamish
hamish_nospam at yahoo.com
Thu Nov 10 22:33:16 EST 2005
Begin forwarded message:
Date: Thu, 10 Nov 2005 19:13:00 -0500
Subject: Re: [GRASSLIST:8983] r.terraflow: wrong data type
Hi Hamish,
I looked at the code. Internally Terraflow uses the same type for
elevation and filled-elevation streams. The truncation to CELL
happens only we convert from the terraflow streams into a GRASS grid.
in main.cc
stream2_CELL(filledstr, nrows, ncols, opt->filled_grid);
should be
stream2_FCELL(filledstr, nrows, ncols, opt->filled_grid);
or more precisely, it should be templated on the elevation type.
Technically this should be corrected, and I'll look into it . Unless
somebody else volunteers in the meantime..
-Laura
Laura Toma
Asst. Professor
Dept. of Computer Science
Bowdoin College
