[GRASS5] v.to.db 2 new features compactness and perimeter
Radim Blazek
radim.blazek at gmail.com
Fri Nov 11 04:18:29 EST 2005
On 11/10/05, Wolf Bergenheim <wolf at bergenheim.net> wrote:
> Heh. defenately not... I use Vect_line_length() to calculate the length.
> perhaps the the fix should go in here? perhaps an additional parameter
> or a new fun Vect_line_length_meters(). I guess that the area is ok? or
> does it have a unit of square degrees? (;
There is Vect_line_geodesic_length but it should only be used with -g flag.
Radim
