[GRASS5] Re: sqlite browser
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Nov 14 04:32:53 EST 2005
On Mon, 14 Nov 2005, Hamish wrote:
>> See also point 22 in SUBMITTING:
>> http://freegis.org/cgi-bin/viewcvs.cgi/*checkout*/grass6/SUBMITTING
>> 22. If you write a shell script and search for a command in $PATH, do
>> NOT use the "which" command or the "type -p" command. Both commands
>> are  not supported on all platforms, thus causing problems for some
>> people.
> Out of curiosity, which platforms is this a problem on?
> Only really old stuff?
Not really too sure any more. I have a vague memory of having a problem
with it some time in the past and then finding that hint in the SUBMITTING
file afterwards. Might have been on IRIX.
Paul
