[GRASS5] Problems about v.surf.idw
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu Nov 17 06:40:17 EST 2005
On Wed, 16 Nov 2005, Muzaffer Ayvaz wrote:
> Firstly thank you for your help;
> But in my second quesiton;
> for(i=0;i<nsearch;i++){
>> the other;
>> /* go thru rest of the points now */
>> for(;i<npoints;i++){
>> What is the rest?? nsearch is either eq! ual to npoints or bigger
> than
>> npoints.
> in the first loop the final i is equal to nsearch -1. So the second loop will be like that:
> for(i=nsearch;i<npoints;i++){
> than npoints.
Only if there are less than 12 points in the map.
> How will this loop be exacuted?
If there are there are more than 12 points in the map, i.e. npoints > 12.
The integer variable npoints in the source code has a different meaning to
the npoints command-line parameter; perhaps that is confusing?
Paul
