[GRASS5] Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
Markus Neteler neteler at itc.it
Fri Nov 18 09:19:21 EST 2005
Hi Irek,
[compilation under Solaris]
I cc to the grass developers list for the INSTALL (install-sh)
problem below (probably 'configure' related):
On Fri, Nov 18, 2005 at 11:03:19AM +1100, Irek.Porebski at csiro.au wrote:
> HI Markus,
> I tried 6.1 version and I had similar problem. I have done this again
> and this is the result.
> GRASS GIS compilation log
> Started compilation: Fri Nov 18 09:01:52 EST 2005
> Errors in:
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/dbf
> s2.9/include/grass \
>         -o OBJ.sparc-sun-solaris2.9/dbfexe.o -c dbfexe.c
> dbfexe.c:22:22: shapefil.h: No such file or directory
> rootksh at theo# ll
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris2
> .9/include/grass
> total 12
> drwxr-xr-x   2 root     other        512 Nov 18 09:05 .
> drwxr-xr-x   4 root     other        512 Nov 18 09:01 ..
> -rw-r--r--   1 root     other       2168 Nov 18 09:05 waterglobs.h
> -rw-r--r--   1 root     other         26 Nov 18 09:02 winname.h
> rootksh at theo# pwd
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/lib/external/shapelib
> rootksh at theo# make clean
> rm -rf OBJ.sparc-sun-solaris2.9
> ../.././install-sh -c  -m 644 shapefil.h
> .9/include/grass/shapefil.h
> make: ../.././install-sh: Command not found
> make: ***
> [/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris
> 2.9/include/grass/shapefil.h] Error 127
> It looks like the path is still incorrect. I have tried start this by
> hand and this help a bit
> rootksh at theo#/bin/sh ../../../install-sh -c  -m 644 shapefil.h
> .9/include/grass
> rootksh at theo# ls -l
> total 44
> -rw-r--r--   1 root     other      17876 Nov 18 09:20 shapefil.h
> Iha done the same in
> /bin/sh ../install-sh -c  -m 644 ../include/*.h
> .9/include/
> But I still connot compile it.
> Started compilation: Fri Nov 18 09:21:24 EST 2005
> Errors in:
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/ogr
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/base
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/db.login
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/display/drivers/XDRIVER
> /XDRIVER24
> rootksh at theo# cd
> gcc -L/usr/sfw/lib
> -L/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
> s2.9/lib
> -Wl,-R,/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-s
> olaris2.9/lib   -o
> .9/driver/db/dbf OBJ.sparc-sun-solaris2.9/column.o
> OBJ.sparc-sun-solaris2.9/cursor.o OBJ.sparc-sun-solaris2.9/db.o
> OBJ.sparc-sun-solaris2.9/dbfexe.o OBJ.sparc-sun-solaris2.9/describe.o
> OBJ.sparc-sun-solaris2.9/driver.o OBJ.sparc-sun-solaris2.9/error.o
> OBJ.sparc-sun-solaris2.9/execute.o OBJ.sparc-sun-solaris2.9/fetch.o
> OBJ.sparc-sun-solaris2.9/listtab.o OBJ.sparc-sun-solaris2.9/main.o
> OBJ.sparc-sun-solaris2.9/select.o OBJ.sparc-sun-solaris2.9/str.o
> OBJ.sparc-sun-solaris2.9/table.o OBJ.sparc-sun-solaris2.9/create_table.o
> -lgrass_dbmidriver -lgrass_dbmibase  -lgrass_sqlp -lgrass_shape
> -lgrass_dbstubs -lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket
> -lgrass_datetime -lm  -lnsl    -lz
> ld: fatal: library -lgrass_dbmidriver: not found
> ld: fatal: library -lgrass_dbmibase: not found
> ld: fatal: library -lgrass_sqlp: not found
> ld: fatal: library -lgrass_shape: not found
> ld: fatal: library -lgrass_dbstubs: not found
> ld: fatal: library -lgrass_gis: not found
> ld: fatal: library -lgrass_datetime: not found
> ld: fatal: File processing errors. No output written to
> .9/driver/db/dbf
> collect2: ld returned 1 exit status
> make: ***
> 2.9/driver/db/dbf] Error 1
> What we can do next?
These are subsequent error. We have to find the bug with the
path to install-sh. I suspect 'configure' here which contains
such a code snippet:
     ac_install_sh="$ac_aux_dir/install-sh -c"
Apparently $ac_aux_dir is set to '.' instead of '..'.
Does any list member have an idea?
Markus
> Thanks,
> Irek
> BST, CSIRO IT
> Queensland Bioscience Precinct
> 306 Carmody Road,
> St Lucia, Brisbane QLD 4067
> Phone (07) 3214 2333
> > -----Original Message-----
> > From: Markus Neteler [mailto:neteler at itc.it]
> > Sent: Thursday, 17 November 2005 5:54 PM
> > To: Porebski, Irek (CSIRO IT, St Lucia)
> > Subject: Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
> > Hi Irek,
> > now I get it:
> > /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/....
> > you are working with the old 6.0 snapshot. Is this
> > intentionally? Let me recommend to got for the 6.1-CVS
> > snapshot which comes with tons of fixes (also some neded for Solaris).
> > Markus
> > On Thu, Nov 17, 2005 at 12:35:01PM +1100,
> > > Hi Markus,
> > > > It should be picked from
> > > > /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-su
> > > > n-solaris2.9/include/grass
> > > > (last -I parameter above).
> > > > Can you please check if it is there?
> > > The "grass" folder doesn't exist. The last folder is:
> > /var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
> > > s2
> > > .9/include
> > > > It should be copied there earlier, while compiling lib/external/
> > > > Probably the 'install' fails in lib/external/shapelib/Makefile
> > > > Please go into
> > > > cd lib/external/shapelib
> > > > and run
> > > > make clean
> > > > make
> > > > and report what's happening there.
> > > s2
> > > make: ***
> > [/var/tmp/1/grass-6.0.cvs_src_snapshot_2005_11_12/dist.sparc-s
> > un-solaris
> > > The path to the "install-sh" is incorrect is should be
> > > ../../../insstall-sh. How to fix this path?
> > Strange! I think that it comes from 'configure', where
> > 'install-sh -c' is defined. But, if possible, use the 6.1
> > snapshot:
>  http://grass.itc.it/grass61/source/snapshot/
> Markus
> > Many thanks,
> > Irek
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica MPBA -
> Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
MPBA - Predictive Models for Biol. & Environ. Data Analysis
