[GRASS5] Re: GRASS and configure
Markus Neteler
neteler at itc.it
Fri Nov 18 17:06:34 EST 2005
Bob,
(cc grass5)
since I am not super expert of configure, I take liberty
to post it here. Hopefully someone will help.
Markus
On Fri, Nov 18, 2005 at 12:44:52PM -0400, Bob Covill wrote:
> Hi Markus,
> I have mostly got the FFMPEG configure stuff working. The problem is
> that ffmpeg consists of 3 libraries (avcodec, avutil and avformat). The
> avcodec library is the one that I need and have set up for in configure.
> Unfortunately, depending on the system avcodec requires avutil.
> My question is; is it possible to spcify two libraries in the
> LOC_CHECK_LIBS() so that the output (FFMPEGLIB in my case) is defined as
> two libraries (i.e -lavcodec and -lavutil)? Or do I have to create
> seperate variables for each library?
> Thanks for your help.
> Bob
