[GRASS5] db.columns and v.info -c
Radim Blazek radim.blazek at gmail.com
Tue Nov 22 04:31:55 EST 2005
On 11/22/05, Maciek Sieczka <werchowyna at epf.pl> wrote:
> Hi
> I'm wondering if functionality of db.columns and v.info -c shouldn't be
> merged into one command. Maybe extend db.columns to report types (other
> info? say: number of records per column, check if null records
> present/absent, number of null records?) and remove "-c" from v.info?
> Maciek
How do you want to merge v. and db. commands?
One works on vector and the other on table.
Radim
