[GRASS5] Re: [GRASSLIST:9066] Compiling Grass on Solaris 9
Markus Neteler neteler at itc.it
Tue Nov 22 06:03:31 EST 2005
Hi Irek,
(cc grass5)
good to hear that the first errors are solved.
The next one seems to be related to [n]curses:
On Tue, Nov 22, 2005 at 02:15:00PM +1100, Irek.Porebski at csiro.au wrote:
> There are new errors:
> Started compilation: Tue Nov 22 11:06:43 EST 2005
> Errors in:
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/lib/init
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/dbf
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/db/drivers/ogr
> rootksh at theo# cd
> rootksh at theo# make
> gcc -L/usr/sfw/lib
> -L/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solari
> s2.9/lib
> -Wl,-R,/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-s
> olaris2.9/lib   -o
> /var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris2
> .9/etc/set_data OBJ.sparc-sun-solaris2.9/set_data.o
> OBJ.sparc-sun-solaris2.9/mke_mapset.o OBJ.sparc-sun-solaris2.9/mke_loc.o
> OBJ.sparc-sun-solaris2.9/chk_dbase.o OBJ.sparc-sun-solaris2.9/other.o
> -lgrass_edit -lgrass_gis -lgrass_datetime -lnsl    -lz  -lsocket
> -lgrass_datetime -lgrass_vask -lncurses  -lm  -lnsl    -lz
> Undefined                       first referenced
>  symbol                             in file
> initscr32
> .9/lib/libgrass_vask.so
> w32addch
> getcurx
> getcury
> ld: fatal: Symbol referencing errors. No output written to
> .9/etc/set_data
> collect2: ld returned 1 exit status
> make: ***
> [/var/tmp/1/grass-6.1.cvs_src_snapshot_2005_11_12/dist.sparc-sun-solaris
> 2.9/etc/set_data] Error 1
> Any suggestion?
> Thanks,
> Irek
I found
 http://grass.itc.it/pipermail/grass5/2004-October/015778.html
but I'm not sure if this helps.
Markus
