[GRASS5] db.columns and v.info -c
Maciek Sieczka werchowyna at epf.pl
Tue Nov 22 13:45:10 EST 2005
On wto, 2005-11-22 at 19:18 +0100, Radim Blazek wrote:
> v.info -c must remain in 6.x.
I see. Thanks for your prompt reply.
Maciek
> You are right that v.db.columns would be better.
> Radim
> On 11/22/05, Maciek Sieczka <werchowyna at epf.pl> wrote:
> > On wto, 2005-11-22 at 15:23 +0100, Markus Neteler wrote:
> > > On Tue, Nov 22, 2005 at 02:53:43PM +0100, Maciek Sieczka wrote:
> > > > > > Hi
> > > > > > I'm wondering if functionality of db.columns and v.info -c shouldn't be
> > > > > > merged into one command. Maybe extend db.columns to report types (other
> > > > > > info? say: number of records per column, check if null records
> > > > > > present/absent, number of null records?) and remove "-c" from v.info?
> > > > > > Maciek
> > > > > How do you want to merge v. and db. commands?
> > > > Isn't v.info -c an example?
> > > No: it shows the columns of a table *connected* to a
> > > vector map.
> > I know.
> > > But you can have many tables not connected to vector maps
> > > in your database. The v.* commands do not see them, but
> > > the db.* commands do see them.
> > > > > One works on vector and the other on table.
> > > > v.info -c works on a table
> > > Yes, but only on a table connected to a certain
> > > vector map.
> > I'm affraid I wasn't explicit enough in my fisrt post. Other words then.
> > Is it necessary to maintain "v.info -c" when db.columns, in conjnction
> > with "v.db.connect -p", provides the same functionality?
> > In order to know what table my_vector is connected to I do "v.db.connect
> > -p my_vector", then db.columns on the resulting table name to learn
> > about it's columns (using v.db.connect for learning the name of
> > connected table is pretty intuitive, as it is used also for connecting
> > and distonecing tables, should be no problems here for newbies).
> > Currently both "v.info -c" and db.columns print the column name -
> > doubled functionality. Only v.info -c prints the column type tough.
> > Instead of maintaing both commands, wouldn't it be better to implement
> > printing the column type in db.columns (or make it print even more
> > information besides coulmn name and type) and get rid of "-c" in v.info?
> > I'm rising this because:
> > 1. I believe that a user will first seek for a command which can
> > describe a table I) among the db.* commands II) v.db.* III) v.* (v.info
> > would be the last reasonable place to look for it if I were a newbie,
> > let's make it easier).
> > 2. I remember one of the goals in Grass>=5.7 was to get rid of doubled
> > functionality.
> > Maciek
> > W polskim Internecie s± setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
> > http://katalog.epf.pl/
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
W polskim Internecie s? setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
