[GRASS5] Re: [GRASSLIST:8559] Re: gshhs
Markus Neteler
neteler at itc.it
Tue Nov 29 04:08:31 EST 2005
On Mon, Nov 28, 2005 at 11:58:12AM -0600, bfdi533 wrote:
> > > Here is the end of what I get now:
> > > D1/3: V1_open_new_nat(): name = gshhs_c
> > > D1/3: Vect_get_thresh(): thresh = 0.000000
> > > D1/3: dig__write_head()
> > > D1/3: write coor size (0) to head
> > > D2/3: coor body offset 14
> > > D3/3: dig_init_plus()
> > > D1/3: dig_spidx_init()
> > > D3/3: dig_cidx_init()
> > > Swapping Enabled
> > > D3/3: Vect_write_line(): name = gshhs_c, format = 0, level = 1
> > > Out of Memory.
> > > Any ideas on where I should go to track this down?
> > I CC to the developer's list. It probably originates from
> Did you ever hear back from the developer's list?
Unfortunately not.
I fear that debugging is needed.
Markus
