[GRASS5] error in French projection definition
Moritz Lennert mlennert at club.worldonline.be
Tue Nov 29 07:44:17 EST 2005
Hello Paul,
below I have copied comments from Vincent (any errors due to translation
are mine) and Mathieu to your remarks.
As mentioned before, I am not an expert and am just trying to relay the
discussion from the French mailing list to the developers in order to
find the best solution.
Paul Kelly wrote:
> Hello Moritz
> On Tue, 22 Nov 2005, Moritz Lennert
>> - Should I change the two files to reflect the correct defintions.
>> Mathieu Basille proposes the following changes:
>> In datum.table : # Nouvelle Triangulation Française ntf "Nouvelle
>> Triangulation Française"      clark80IGN dx=-168.0 dy=-60.0
>> dz=320.0
> First of all that should be "Nouvelle_Triangulation_Francaise" even
> if it is not quite grammatically correct. It should correspond to the
>  official EPSG name which only uses ASCII characters. I have now
> added a comment to datum.table to indicate that.
Ok, thanks for changing that (although I didn't find the comment you
said you added).
>> In ellipse.table : # Clarke 1880 IGN clark80IGN      "Clarke 1880
>> IGN"               a=6378249.200 f=1/293.466021294
> Two things: 1) The differences are so small from the version already
> in GRASS that it's not clear to me how big a difference it would make
>  (although I could be wrong). What is the problem that resulted in
> the proposal for these changes?
Mathieu:
> I don't know exactly the induced problems (probably a couple of
> meters...). But I really think that the problem is not there. The
> Clark80 as defined in GRASS is the same that the one used by ArcView
> (if I'm not wrong) and therefore is the most used in France. The
> problem is that it doesn't correspond to the OFFICIAL parameters that
>  we SHOULD use in France, to do things right. It's more a problem of
> principles than a problem of real troubles in the projections. If
> GRASS is supposed to do a good work, it has to implement the correct
> and official parameters.
> 2) I would rather fix the existing clark80 definition to get it right
>  than introduce an alternative different version.
Mathieu:
> I agree on that point. I just added a second one to be able to import
>  ArcView layers (with the Clark80 ellipsoid) in different ways. But
> I'm not sure that's still needed with the option "Create a new
> location" when you import a layer.
So the question is whether the current definition of the Clark80
ellipsoid is useful for anything else. In datum.table, the carthage
datum also references it.
On
http://www.globalsecurity.org/military/library/policy/army/fm/6-2/appe2.htm
(random google search) at the bottom, note 1, reads:
"a. Note 1. Any entry reading SEE NOTE ONE in Tables E-3 through E-25 of
this appendix are so noted because of inconsistent listings of datums
referenced to the Clarke 1880 ellipsoid. Table E-1 lists five different
Clarke 1880 ellipsoids. DMA has adopted only one. Different countries
have adopted different dimensions for the Clarke 1880 ellipsoid. These
differences depend on two things: which of Clarke's original numbers
were used ([a, b] or [a, f]) or which foot-to-meter conversion was used.
(1) In areas referenced to the ARC 1950 datum, the Clarke 1880
dimensions adopted are shown below.
a: 6378249.145326     b: 6356514.966721     f: 1/293.4663076
(2) In areas referenced to Carthage, Merchich, and Voirol datums, the
adopted dimensions are shown below.
a: 6378249.2     b: 6356515.0     f: 1/293.46598
(3) The DMA-adopted dimensions are shown below.
a: 6378249.145     b: 6356514.8696     f: 1/293.465
(4) DMA TM 8350.2 with Insert 1 lists datum transformation parameters
for local datums referenced to the DMA-adopted Clarke 1880 and not the
dimensions adopted by other countries. Any datum with SEE NOTE ONE in
the DDCT CODE column should be transformed to other datums with the
user-defined option. "
So there might no be one single "correct" definition of this ellipsoid.
> For better datum transformation you can also use nadgrids: france.gdb
>  in the PROJ_INFO file (instead of dx,dy,dz) Get the france.gsb file
> at http://www.stjohnspoint.co.uk/gis/france.htm I should maybe see
> about integrating this file into the GRASS distribution as it is hard
>  to find good datum transformation parameters for France.
Vincent:
> Great to see that others have worked on the problem of creating a
> conversion grid NTF->GRS80 !
> One other thing to look out for is the way to specify the Lambert
> Conformal Conic projection with GRASS/PROJ. I suspect g.setproj has
> some bugs with regard to this as there is more than one way of
> specifying the parameters for this projection. But I'm not too sure
> about it all, just have an uneasy feeling!
Vincent:
> The Lambert Conformal Conic projections used in France are: - either
> tangent with scale factor on both sides of the automecoic parallels -
> or secant (equivalent definitions) You can find more information on
> the website of the IGN,
See for example http://www.ign.fr/telechargement/FAQ/FAQ10.pdf (in
english) and http://www.ign.fr/telechargement/FAQ/FAQ5.pdf.
>> - Or is this handled by proj ? What is the relation between the two
> The ellipse.table file in GRASS dates from the mid-late 1980s and was
>  originally only used by some d.* commands that converted UTM
> co-ordinates to lat/long. It pre-dates the introduction of PROJ into
> GRASS in the early 1990s as far as I know.
Mathieu:
> I have to admit that I'm totally lost at this point. I don't
> understand at all the relation between GRASS and PROJ... I thought
> that setting the good ellipsoid and datum in GRASS and then setting
> precisely the LCC projection used in France (with the right
> parameters) would suffice.
> I'll try to play a bit with the france.gdb file... But I'm not sure
> to understand exactly how it can help me. Do I really need to use the
>  RGF93 datum for french projections ??? Uh... It's definitely not as
> simple as I expected... What a mess to use french projections for my
> job !
Moritz
