[GRASS5] Jpeg2000
Jeshua Lacock
jeshua at OpenOSX.com
Sun Oct 2 02:51:53 EDT 2005
On Sep 28, 2005, at 6:09 PM, Hamish wrote:
> Yes GDAL supports JPEG2000, but you will have to check that the driver
> you need has been activated. Try running this command to see if you
> have
> JPEG2000 support in your copy of GDAL:
> gdalinfo --formats | grep 2000
> gdalinfo <filename>
> If you are using Lorenzo Moretti's Mac binaries, JPEG2000 should be
> supported. If you aren't, I highly recommend them.
> http://wwwamb.bologna.enea.it/forgrass/
I am curious why you might recommend Lorenzo's binaries over OpenOSX's
free stand-alone GRASS application?
OpenOSX's application has the following advantages over Lorenzo's
binaries: OpenOSX Grass is a complete stand-alone application requiring
zero installation, it has built-in Mac OS X 10.4 support (no update
required), and is based on GRASS 6.0.1 versus Lorenzos which is based
on GRASS 6.0.0...
The OpenOSX Grass application also supports JPEG2000, and OpenOSX was
the first to package Grass for Mac OS X and has been making free GRASS
binaries available for almost 5 years now.
OpenOSX Grass is available as a free download from:
<http://OpenOSX.com/grass>
Cheers,
Jeshua Lacock ___________________________
Programmer/Owner Phone: 877.240.1364
http://OpenOSX.com Fax: 415.462.6211
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
