[GRASS5] some new r3.* modules and updates in grass6.1-cvs
Helena Mitasova hmitaso at unity.ncsu.edu
Tue Oct 4 10:10:41 EDT 2005
I submitted it a day or two ago, please check it out - it would be
useful to test it a little more. I hope I did it correctly.
Helena
Michael Barton wrote:
> Helena,
> I put menu items for these modules in the current GIS Manager with the hope
> that they'd be out soon. I might need to double check the module name in the
> menu, however.
> Michael
> __________________________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ 85287-2402
> phone: 480-965-6213
> fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
>>From: Helena Mitasova <hmitaso at unity.ncsu.edu>
>>Date: Wed, 28 Sep 2005 14:17:29 -0400
>>To: Soeren Gebbert <soeren at pool.math.TU-Berlin.DE>
>>Cc: <grass5 at grass.itc.it>
>>Subject: Re: [GRASS5] some new r3.* modules and updates in grass6.1-cvs
>>I just tested r3.out.rast and r3.in.rast (we would like to use it to
>>store time series output from simwe).
>>It seems to work well, but r3.in.rast is not in the current CVS - is
>>anybody planning to add it? I can do it if there is nobody who can do it
>>faster than me. I got it from here:
>>http://www-pool.math.tu-berlin.de/~soeren/grass/modules/
>>Soeren, thank you very much for this - it should make managing numerous
>>sets of time series much easier,
>>Helena
>>Soeren Gebbert wrote:
>>>Hi all,
>>>i've made some changes to the following modules and implemented a new
>>>one in the current grass6.1-cvs:
>>>Updates:
>>>g.mremove
>>>* added rast3d support
>>>r3.to.rast
>>>* better error handling (G_unopen_cell)
>>>r3.out.vtk
>>>* added new flag "-o" -- the scalefactor effects the origin
>>>r.out.vtk
>>>* documentation update
>>>* added new flag "-p" -- pointdata support if no elevation map is given
>>>* added new option -- elevation value for 2D data
>>>New module:
>>>r3.in.rast
>>>* converts 2d raster maps into one G3D map
>>>* the number of 2D maps can be less than the depths of the G3D region, the
>>>  last 2D map is used to fill the G3D raster
>>>This module works only if the G3D resolution is equal to the current
>>>window resolution.
>>>Thats all for the moment.
>>>I want to implement a new module which produces cross-section 2D maps
>>>from a G3D map by a given 2D elevation map.
>>>All modules and diffs (for CVS) are available at:
>>>Because i have no CVS write access, it would be nice if somebody with
>>>write access can add the changes to the cvs. The needed diff's are
>>>available at my homepage (the link above).
>>>It would be great too,
>>>if somebody can test these modules, because i have only 2 test datasets.
>>>The modules are working fine at my machine (Fedora Core 3 Linux 32bit
>>>kernel 2.6.12, AMD 3000+ 512Mb RAM, grass6.1-cvs), but please use only
>>>testdatasets to prevent damage on your data, because im not able to
>>>emulate all errors which i try to handle ... .
>>>Feel free to send me any comments, hints and critism about the modules.
>>>Best regards
>>>Soeren Gebbert
>>>_______________________________________________
>>>grass5 mailing list
>>>http://grass.itc.it/mailman/listinfo/grass5
