[GRASS5] [bug #3710] (grass) d.m - store commands in the history
Tue Oct 4 20:29:16 EDT 2005
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=3710
> Subject: d.m - store commands in the history
> Commands called from the d.m are not stored in the Grass history.
> Would it be possible to store them? I think it would be very
> usefull, anybody too?
Are you referring to ~/.bash_history (and similar)? Those files belong
to the shell; d.m shouldn't be messing with them.
Arguably d.m should have its own command history, but that's a
separate issue.
