> - update from cvs the usual way make sure that is: cvs update -dP > - su you cannot build a package as a regular user? > The only problems I find are: > - during cvs update some files are conflicting (as a result of previous > compilations); it seems necessary to delete them for a successful compilation did you run 'make distclean' first? Hamish
