[GRASS5] GDAL GRASS Plugin Updated
Michael Barton
michael.barton at asu.edu
Wed Oct 5 02:27:57 EDT 2005
Frank,
Will the new gdalwarp read ASTER hdf files and their GCP's yet? This worked
with 1.2.6 and broke subsequently. The last time I tried it (a couple weeks
back with 1.3), it still gave me an error.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Frank Warmerdam <warmerdam at pobox.com>
> Reply-To: Frank Warmerdam <warmerdam at pobox.com>
> Date: Fri, 30 Sep 2005 17:38:39 -0400
> To: grass5 developers list <grass5 at grass.itc.it>
> Subject: [GRASS5] GDAL GRASS Plugin Updated
> Folks,
> I have updated the GDAL plugin driver for GRASS to include a
> fix for raster projections, and to include support for vector data
> (based on Radim's new driver).
> http://www.gdal.org/dl/gdal-grass-1.3.1.tar.gz
> You should be able to build and install it after installing GDAL and
> then GRASS to avoid the otherwise cyclic dependency of
> GDAL on GRASS (and GRASS on GDAL). I think it will work fine
> with GDAL 1.3.0 as well as the 1.3.1 (now in alpha).
> Thanks to Radim for the code, and Markus for guilting me into finally
> acting. :-)
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
