[GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in
the monitor history
Michael Barton
michael.barton at asu.edu
Wed Oct 5 02:34:57 EDT 2005
Hamish,
Can you (or someone) add this to d.rast.arrow and d.rast.num so that a
display with these features can be output to a graphics file using
d.out.file? Are there any more commands (excluding mouse placement) that
need this?
With regard to mouse placement, it would be nice if when placing something
with a mouse (e.g. A scalebar), the coordinates could be read on the mouse
click and pasted into the coordinate field so that the feature could be
saved.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Mon, 3 Oct 2005 18:27:24 +1300
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in
> the monitor history
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3704
>> Subject: d.rast.arrow does not save a line in the monitor history
>> GRASS Version: GRASS 6.1.cvs (2005)
>> Name: David Finlayson
>> d.rast.arrow does not appear to write a line in the monitor history.
>> As a result, d.save, d.out.png (what else?) do not put the arrow
>> command in their output.
>> I wonder if this is the reson that d.zoom does not work with
>> d.rast.arrow? There is another bug (Tracking ID 2012) that may be
>> related.
> d.rast.arrow isn't saved to the command history. Easy enough to add this
> by putting this:
> D_add_to_list(G_recreate_command());
> towards the end of the main{} function in arrow.c.
> Same with d.rast.num.
> Any d.redraw type command depends on what is saved to the window's
> command history list (see d.save). Sometimes this isn't what was entered
> on the command line (eg d.text and d.barscale -m).
> Another question:
> Do the default fonts (romans et. al) have an arrow char built in?
> (distant memory that they did?) If so we could use it with
> R_text_rotation() to improve to a 360 degree resolution arrow drawing
> for standard GRASS aspect maps and ANSWERS aspect maps instead of the
> current 8-way ones... maybe freetype same-char compatibility issues.
> Hamish
