[GRASS5] compilation errors 6.cvs on MacOS
Scott Mitchell smitch at mac.com
Thu Oct 6 10:31:57 EDT 2005
After months of distraction, I've been updating various GRASS
installations here.  The latest 6.x CVS (grass6 head) compiled fine
on a linux machine here, but gets errors on MacOSX.  Looking at the
errors, I think that they're all related to the first error, in the
display libraries.  When I try to make that directory I get the
following, which doesn't mean much to me:
[smitch at stipa:~/src/cvsgrass/grass6/display/drivers/lib]$ make
ar cr /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/
cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a
OBJ.powerpc-apple-darwin8.2.0/Box_abs.o OBJ.powerpc-apple-darwin8.2.0/
Box_rel.o OBJ.powerpc-apple-darwin8.2.0/Client.o OBJ.powerpc-apple-
darwin8.2.0/Clr_table.o OBJ.powerpc-apple-darwin8.2.0/Color.o
OBJ.powerpc-apple-darwin8.2.0/Cont_abs.o OBJ.powerpc-apple-
darwin8.2.0/Cont_rel.o OBJ.powerpc-apple-darwin8.2.0/Erase.o
OBJ.powerpc-apple-darwin8.2.0/Font_get.o OBJ.powerpc-apple-
darwin8.2.0/Get_t_box.o OBJ.powerpc-apple-darwin8.2.0/Linemod.o
OBJ.powerpc-apple-darwin8.2.0/Move_abs.o OBJ.powerpc-apple-
darwin8.2.0/Move_rel.o OBJ.powerpc-apple-darwin8.2.0/Num_colors.o
OBJ.powerpc-apple-darwin8.2.0/Plydts_abs.o OBJ.powerpc-apple-
darwin8.2.0/Plydts_rel.o OBJ.powerpc-apple-darwin8.2.0/Plylne_abs.o
OBJ.powerpc-apple-darwin8.2.0/Plylne_rel.o OBJ.powerpc-apple-
darwin8.2.0/Polygn_rel.o OBJ.powerpc-apple-darwin8.2.0/Raster_int.o
OBJ.powerpc-apple-darwin8.2.0/Raster_chr.o OBJ.powerpc-apple-
darwin8.2.0/Raster_def.o OBJ.powerpc-apple-darwin8.2.0/Reset_clrs.o
OBJ.powerpc-apple-darwin8.2.0/Respond.o OBJ.powerpc-apple-darwin8.2.0/
Returns.o OBJ.powerpc-apple-darwin8.2.0/Set_window.o OBJ.powerpc-
apple-darwin8.2.0/Text.o OBJ.powerpc-apple-darwin8.2.0/Text_size.o
OBJ.powerpc-apple-darwin8.2.0/Work.o OBJ.powerpc-apple-darwin8.2.0/
clip.o OBJ.powerpc-apple-darwin8.2.0/color_supp.o OBJ.powerpc-apple-
darwin8.2.0/command.o OBJ.powerpc-apple-darwin8.2.0/connect_fifo.o
OBJ.powerpc-apple-darwin8.2.0/connect_sock.o OBJ.powerpc-apple-
darwin8.2.0/font.o OBJ.powerpc-apple-darwin8.2.0/main.o OBJ.powerpc-
apple-darwin8.2.0/pad.o OBJ.powerpc-apple-darwin8.2.0/utils.o
OBJ.powerpc-apple-darwin8.2.0/RGB.o OBJ.powerpc-apple-darwin8.2.0/
Text2.o OBJ.powerpc-apple-darwin8.2.0/Text3.o OBJ.powerpc-apple-
darwin8.2.0/font_freetype.o; ranlib /private/Network/Servers/
gracilis.carleton.ca/home/smitch/src/cvsgrass/grass6/dist.powerpc-
ar: /private/Network/Servers/gracilis.carleton.ca/home/smitch/src/
cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/libgrass_driver.a:
Resource temporarily unavailable
ranlib: file: /private/Network/Servers/gracilis.carleton.ca/home/
smitch/src/cvsgrass/grass6/dist.powerpc-apple-darwin8.2.0/lib/
libgrass_driver.a is not an archive
make: *** [/private/Network/Servers/gracilis.carleton.ca/home/smitch/
libgrass_driver.a] Error 1
Is that enough for anyone here to understand what's wrong?  Any
suggestions what to try?
Thanks,
Scott Mitchell
smitch at mac.com
