[GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in the monitor history
Michael Barton michael.barton at asu.edu
Wed Oct 12 02:27:00 EDT 2005
Hamish,
This looks great. I could have really used this in a paper on modeling
Viking seafaring last year. But we are going to do another one soon, so I'll
have a chance to try this out.
With respect to negative magnitudes, I like your idea. It would accurately
visually indicate the data. An alternate color would make it stand out even
more, but that probably complicates things too much.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Hamish <hamish_nospam at yahoo.com>
> Date: Wed, 12 Oct 2005 19:05:02 +1300
> To: Michael Barton <michael.barton at asu.edu>
> Cc: <grass-bugs at intevation.de>, <david.p.finlayson at gmail.com>,
> <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in
> the monitor history
> [d.rast.arrow too cluttered to be useful]
>>> g.region rast=source_map
>>> d.rast source_map
>>> g.region res=  (res * 16)
>>> d.rast.arrow ...
>>> perhaps that leads to aliasing problems?
>> This seems to work, but it is clunky. I could of course script a way
>> to change resolution, display arrows, and change it back again.
>> However, I wonder if this is desirable enough, when you make your
>> improvements to d.rast.arrow, that it is worthwhile to include a
>> (temporary) resolution setting in the module itself?
> Done & in CVS.
> d.rast.arrow now can take a raster map for arrow magnitude and there is
> a new skip option to only draw arrows every Nth cell.
> screenshot showing raster elevation level, with arrow direction and size
> controlled by aspect and slope maps (created with r.slope.aspect); skip
> factor set to only draw every third cell; and grid color set to "none":
>   http://bambi.otago.ac.nz/hamish/grass/d_rast_arrow_magnitude.png
> The question remains what to do if fed negative magnitudes. Right now I
> have it skipping over that arrow (as it does for NULL values), but it
> could take the absolute value or rotate the arrow 180 degrees.
> enjoy,
> Hamish
