[GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in
the monitor history
Michael Barton
michael.barton at asu.edu
Wed Oct 12 11:49:47 EDT 2005
A negative magnitude is not necessarily an error, but could have real
meaning.
Michael
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
phone: 480-965-6213
fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Daniel Calvelo Aros <dcalvelo at minag.gob.pe>
> Reply-To: <daniel.calvelo at minag.gob.pe>
> Date: Wed, 12 Oct 2005 10:02:02 -0500
> To: Hamish <hamish_nospam at yahoo.com>, Michael Barton <michael.barton at asu.edu>
> Cc: <grass-bugs at intevation.de>, <david.p.finlayson at gmail.com>,
> <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #3704] (grass) d.rast.arrow does not save a line in
> the monitor history
> From: Hamish <hamish_nospam at yahoo.com>
> Sent: Wed, 12 Oct 2005 19:05:02 +1300
>> Done & in CVS.
>> d.rast.arrow now can take a raster map for arrow magnitude and there
>> is a new skip option to only draw arrows every Nth cell.
>> screenshot showing raster elevation level, with arrow direction and size
>> controlled by aspect and slope maps (created with r.slope.aspect); skip
>> factor set to only draw every third cell; and grid color set to "none":
>> http://bambi.otago.ac.nz/hamish/grass/d_rast_arrow_magnitude.png
>> The question remains what to do if fed negative magnitudes. Right
>> now I have it skipping over that arrow (as it does for NULL values),
>> but it could take the absolute value or rotate the arrow 180 degrees.
> I'd say keep the current skip, but issue a warning; whatever the cartographer
> needs to do he can using r.mapcalc (tell him in the warning and the docs).
> The other possibility is to add an option, but I've the impression it somehow
> reduces flexibility...
> Daniel.
