[GRASS5] [bug #3735] (grass) v.build.polylines: DB connection lost
Request Tracker grass-bugs at intevation.de
Wed Oct 12 15:49:24 EDT 2005
this bug's URL: http://intevation.de/rt/webrt?serial_num=3735
Subject: v.build.polylines: DB connection lost
grass obtained from: CVS
grass binary for platform: Compiled from Sources
I have a polygon map 'sids' imported from SHAPE:
v.db.connect -p sids
Vector map <sids> is connected by:
layer <1> table <sids> in database </home> through driver <dbf> with key <cat>
which I want to rebuild with v.build.polylines (in order to later calculate
the boundary lengths with v.to.db). But:
v.build.polylines sids out=sids_polyline
v.db.connect -p sids_polyline
FEHLER: Database connection for map <sids_polyline> is not defined in DB
        file
It would be nice if the DB support could be added to v.build.polylines.
Markus
-------------------------------------------- Managed by Request Tracker
