[GRASS5] Re: [bug #3362] (grass) r.proj works ONLY when source
and target mapset names are identical
Hamish
hamish_nospam at yahoo.com
Mon Oct 17 06:02:53 EDT 2005
> > Maciek Sieczka via RT wrote:
> > > Fixed by Paul Kelly.
> > > All,
> > > That would be practical if you close bugs you have fixed. Thanks.
> > I had left it open because there was an ongoing discussion about
> > G_tempfile() usage which applied to other modules than r.proj too.
> > Probably nobody will read it now the bug has been resolved. I just
> > wasn't sure how to deal with that kind of thing...
> Right, I have created a new bugtracker entry for this issue.
> My remark about closing fixed bugs was just a general note to all. In
> most cases we want fixed bugs to be closed, while developers often
> forget to do it. As well as the users often fail to confirm whether
> the fix is ok for them when they are asked to...
note that it is possible and easy to change a bug's title, area, and
priority so that if a bug evolves into something else the history can be
easy to follow and a new bug doesn't need to be opened.
Hamish
