[GRASS5] [bug #3749] (grass) v.patch: 3d vector + 3d vector = 2d
vector
Michael Barton
michael.barton at asu.edu
Tue Oct 18 12:02:49 EDT 2005
THANKS VERY MUCH for the offer, Martin. If you do, could you look into
adding an option to merge attributes too? At least for vector files that
have identical attribute structures, it should be possible to append the
attributes of the files like the spatial objects. I did a little script hack
that does this via OGR (v.append), but doing it correctly in the v.patch
module would be much better.
Michael
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
> From: Martin Landa <landa.martin at gmail.com>
> Date: Mon, 17 Oct 2005 15:30:16 +0200
> To: grassdev <grass5 at grass.itc.it>
> Subject: Re: [GRASS5] [bug #3749] (grass) v.patch: 3d vector + 3d vector = 2d
> vector
> Hi,
> is anyone working on it? May I try to fix it? I am bored;-)
> Best,
> Martin
> 2005/10/17, Request Tracker <grass-bugs at intevation.de>:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=3749
>> Subject: v.patch: 3d vector + 3d vector = 2d vector
>> If you run v.patch with multiple 3D vector files, the output is always 2D and
>> the z-data is lost. :(
>> Hamish
>> -------------------------------------------- Managed by Request Tracker
>> grass5 mailing list
>> http://grass.itc.it/mailman/listinfo/grass5
