[GRASS5] [bug #3743] (grass) v.in.gns DB error
Markus Neteler via RT grass-bugs at intevation.de
Tue Oct 18 18:08:20 EDT 2005
Thanks for the report.
> Trying to import GNS data into GRASS failed using both MySQL and Postgres as
> backbones. With Postgres the error lies in the v.in.gns: the table
> definition requires to 'double precision' rather than just 'double'.
fixed.
> Changing that makes postgres work.
Tested, confirmed.
> With MySQL the error lies in the 'long' for longitude in the table
> definitionin v.in.gns. Changing it to 'lon' makes this first step work,
Fixed.
> but  then subsequent steps in the driver fail, I guess these are a more
> general mysql driver error.
I have no running mysql here, so someone else may test.
Markus
-------------------------------------------- Managed by Request Tracker
