[GRASS5] [bug #3742] (grass) r.out.bin output incorrect
 compared with r.out.netcdf
    Hamish
    hamish_nospam at yahoo.com
    Tue Oct 18 19:02:38 EDT 2005
> > > Subject: r.out.bin output incorrect compared with r.out.netcdf
> > > > []% r.out.bin -h null=NaN in=srtm out=srtm.grd
> > note null=NaN should not work [yet it does! G_parser bug!].
> G_parser() doesn't actually check that argument values are legitimate
> unless the ->options field is non-null.
I didn't know that. Ok, it's just a string.
Should it be testing the string against opt->type? (,opt->multiple)
(ie is there a reason not to do so, or has it just not been done yet?)
> > As written r.out.bin will only take an integer for the null value at
> > the command line.
> r.out.bin doesn't check the return value from sscanf().
I've already added that test in CVS/HEAD.
Glynn, I was hoping you would know the answer to the outstanding GMT
header code byteswap question?
    /* Set up Parameters for GMT header */
    if (flag.gmt_hd->answer) {
	if (flag.swap->answer)
	    TIFFSwabLong((uint32 *) & null_str);
	sprintf(buf, "%d", null_str);
does this pollute null_str byteswapping later on in the code?
 (ie swapping an already swapped variable)
also should that (and the rest of the code) test be
if (swapFlag)
 not
or should "swapFlag" be renamed something better?
The mix & match of using both has gotten me a bit confused, hopefully
it is all ok.
Hamish
