[GRASS5] [bug #3748] (grass) d.m: v.topo.check - no such command in Grass61
Markus Neteler neteler at itc.it
Wed Oct 19 05:22:36 EDT 2005
Request Tracker wrote:
>this bug's URL: http://intevation.de/rt/webrt?serial_num=3748
>Subject: d.m: v.topo.check - no such command in Grass61
>Platform: GNU/Linux/i386
>grass obtained from: CVS
>grass binary for platform: Compiled from Sources
>GRASS Version: cvs 17.10.2005
>d.m -> Vector -> Develop map -> Break lines at intersections:
>couldn't execute "v.topo.check": no such file or directory
I think that the menu entry is wrong in d.m:
thuille:d.m[1096.45] grep v.topo.check *
menu.tcl:                        {command "Break lines at intersections"
{} "v.topo.check" {} -command {execute v.topo.check }}
It should not be v.topo.check. In fact it will be something like
v.clean  - break: break lines at each intersection
Markus
