[GRASS5] [bug #3746] (grass) d.grid compilation error
Hamish
hamish_nospam at yahoo.com
Wed Oct 19 17:10:27 EDT 2005
> Looks like d.grid has been changed so it uses PROJ but the Makefile
> not totally updated accordingly. Could you try adding the line
> EXTRA_INC = $(PROJINC)
> to display/d.grid/Makefile and see if that makes any difference?
> Paul
> > /wall/grass-6.1.cvs_src_snapshot_2005_10_15/include/gprojects.h:67:
> > error: syntax error before '*' token
> > /wall/grass-6.1.cvs_src_snapshot_2005_10_15/include/gprojects.h:68:
> > warning: data definition has no type or storage class
> > /wall/grass-6.1.cvs_src_snapshot_2005_10_15/include/gprojects.h:72:
> > error: syntax error before "OGRSpatialReferenceH"
I tried compiling d.grid yesterday with an older version of gcc and got
a different error. (all sorts of undefined pj_ functions). Adding
$(GPROJLIB) to the LIBES line fixed that. d.where's Makefile uses the
following:
LIBES = $(DISPLAYLIB) $(RASTERLIB) $(GPROJLIB) $(GISLIB)
DEPENDENCIES= $(DISPLAYDEP) $(RASTERDEP) $(GPROJDEP) $(GISDEP)
should the PROJ references be added to all three of these lines in the
d.grid Makefile, as a set?
Hamish
