[GRASS5] Re: question about sqlite
Otto Dassau
dassau at gdf-hannover.de
Thu Oct 20 02:42:37 EDT 2005
Am Mittwoch, 19. Oktober 2005 22:11 schrieb Daniel Calvelo Aros:
> You're welcome :)
> BTW, for beginning to work in SQL (and understand a lot about relational
> databases), sqlite is truly great. You need only one executable file and
> you're set. Along with any SQL tutorial, it should get you experimenting
> with SQL in minimal time. And the code is beautifully written and
> commented. Really, it's one of the nicest sourcebases around.
> About speed, I'm pretty sure that SQLite *can* be much faster than our DBF
> driver, given proper index management. I haven't looked in detail at
> Radim's work, so can't really comment on that.
