[GRASS5] d.vect -a|c for all types ver2
Martin Landa
landa.martin at gmail.com
Thu Oct 20 11:15:31 EDT 2005
Hi all,
playing with v.patch and 3d vector maps I found a new bug in my
patches for d.vect:-(
When I try to display 3d vector map layer (trees created by trees.pl
script, see http://www.fle.czu.cz/~jachym/programs/trees.html) I get
error message "Attempt to read topo for dead isle" from function
Vect_get_area_isle(). There is temporary solution:
area.c:
- if (Vect_get_isle_area (Map, area)) { /* isle ? */
+ if (!Vect_is_3d (Map) && Vect_get_isle_area (Map, area)) { /* isle ? */
I know it is not nice ... but it works for now.
Martin
2005/10/18, Martin Landa <landa.martin at gmail.com>:
> Hi Markus,
> 2005/10/18, Markus Neteler <neteler at itc.it>:
> > I tried, works well for areas and lines. But should it do also for points?
> > I can submit as is and then (if time permits) you may get it
> > working for points as well?
> you are right, there is a bug, I have tested it only with
> icon=basic/box and it worked.
> I hope it is better now. Please, see png's at
> http://k153-85.fsv.cvut.cz/~martin/.../d.vect-ac/
> Any comments?
> Best regards,
> Martin
Type: application/x-gzip
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20051020/c157a617/d_vect_rgb_column-2005-10-20.diff.gz
