[GRASS5] Re: [bug #3709] (grass) d.m - commands output pollutes the Grass terminal
Fri Oct 21 09:28:09 EDT 2005
Michael Barton wrote:
> If you think it is better then to reopen this bug number for a different
> issue, I guess that is your call. It just seemed to me that we solved the
> first issue. Now that it's solved, another issue has become apparent. This
> is often the case. I just want to make sure that the appropriate people take
> a look at this. It's not d.m per se, but any commands (or possibly d.rast).
> You'd get the same result if you did this from the command line.
Yes, but if the commands are invoked by d.m, d.m should arguably be
redirecting stdout and stderr to its internal log window.
