[GRASS5] Re: [bug #3709] (grass) d.m - commands output pollutes the Grass terminal
Maciek Sieczka werchowyna at epf.pl
Thu Oct 27 16:20:02 EDT 2005
Michael Barton wrote:
<snip>
> There are a couple minor cosmetic issues
> First
> The progress display is a series of percent values. They would look nicer on a new line following the d.rast
> command and if each value overwrote the prior one.
I recall an issue with percenatage series in other modules:
http://article.gmane.org/gmane.comp.gis.grass.devel/4982
Related?
> Second, if I induce an error in d.rast, it generates a TclTk error. These
> are somewhat more difficult to understand than normal GRASS error
> messages--though not incomprehensible. All other panel command errors go to
> the GIS Manager output window. Only d.rast still generates a TclTk error.
Shame, but we can live with this.
> I also changed the monitor control buttons to radiobuttons. This should
> address a wish you had several months back. The buttons indicate which
> monitor is currently active. If that wish ever got a number, you can close
> it.
That's a really handy feature.
Cheers,
Maciek
W polskim Internecie s? setki milionów stron. My przekazujemy Tobie tylko najlepsze z nich!
http://katalog.epf.pl/
